'35 clutch adjustment
Hello, after a 4 1/2 year layup, the engine is back in the car. The clutch disc was reworked and run prior to the layup. When I was removing the engine I scored the area where the throw out bearing rides. I obtained a NOS pressure plate. I checked the pressure plate "finger" settings prior to installing.
My problem is the clutch pedal when depressed does not completely disengage the transmission from the flywheel. The clutch pedal linkage appears to be correctly adjusted...it seems it does not have enough "throw" to move the pressure plate to completely disengage the transmission from the flywheel. I assume I need to pull the transmission to the pressure plate.
Thank you. Regards, Tom
There should be three holes in the lever that the pedal link connects to. Move the link to the inner hole.0
geoff, thank you for the quick reply. ..already in the inner hole...linkage adjusted so all slack out, any other ideas?
thank you. regards, tom
Just checking, what was the thickness of the gasket you used between the pressure plate and the flywheel.?y0
A timely post, I'm just about to connect up the operating mechanism on a 35 H8. I've seen the 3 holes in the lever and wondered why 3 holes?Geoff, when you mention connecting the link to the inner hole, do you mean the middle hole of the 3?0
It depends on how much throw you have Bob. Moving to the inner hole gives more throw, but makes the pedal a little harder to push in, something a strapping bloke like you should have no trouble conquering! Sometimes with a re-corked clutch there is not enough adjustment for correct freeboard of the pedal, so moving the link closer to the centre increases the movement available.0
Hello, les, I used the one supplied in the overhaul kit by dale cooper...same gasket I used before the latest engine removal. I do not know the dimension..thin, but I do not have a number....good thought though.
My latest theory is the corks may have been on the long side, the clutch disc sat uncompressed for 4.5 years and perhaps they just need to be compressed for a bit...as after siting over a long weekend the clutch is working as normal using the inner most hole with all slack/slop out of linkage. I will post if the circumstances change. My thanks to all. Regards, Tom0 -
Bob, I believe Geoff is referring to the hole closest to the "axle" of the brake linkage. As Geoff mentions, hole furthest from the axle gives the operator the best leverage, hence lightest pedal force, but provides the least amount of "action" in the mechanism..I.e. less "throw". Regards, Tom0
- 96 Essex Super 6
