HydraMatic Shifter Parts Needed
SuperDave
Here are the pictures of the parts I have. I also ordered the reproduction indicator needle and plastic lens. I think there is a cover or plate that goes on the back side. Also a check ball and spring. Something has to hold it together.. screws? Pivot pin? I do have the two large screws that clamp it to the column. As you can see.. it's not for show but needs to be functional.
Thank You! ( Looks like mine except it's complete.) I put in a bid, will have to wait and see.0
Dave, did you win the part on eBay? If not, I have what you need for your hydramatic. Let me know.
John0 -
Got it, Thanks!0
