8 cyl exhaust manifold stud centres
Bob, if your asking can you fit a 1937 manifold on the 1934/5 motor,the answer would be no,as the later 8's have completely different gaskets and have bigger ports.0
Yes the 37 manifold has bigger ports--it will still provide some performance increase over the early manifold. Would not bet good to go the other way and put a small port manifold on a big port block!The stud spacing is the same for both--correct? Can someone hold the two gasket styles together--one over the other to confirm.0
Forget it! The manifolds are not interchangeable.0
Its taken a while but I can now answer my own question.The exhaust stud spacing for 34/5 8s is subtly different to that of the later 8s. About half a stud width here and there.0
All, these answers seem odd to me, being that I have a 49 manifold on what is a early narrow block , So late manifold early block???. Must fit? About 45 years ago I knew a fellow who restored a 31 Hudson using all original engine parts on a 47 block.. They all ran fine..1
- 96 Essex Super 6
