Steering drop arm
pmlmbigpondcom
G'day All,
Does anyone know of a source for NOS steering drop arms for a 1937 steering box ?
I have two and they both have the ball on the end almost cut off by wear
Other wise I will have to have one repaired and I am a bit dubious about that.
Thanks
Phil
Australia
Thanks
Phil
Australia
Phil, you didn't tell them your car is right hand drive - the drop arm will face the other way!!! Like the Irish carpenter had to keep the nails with the sharp end facing him to use on the other side of the house.0
I was actually, but then realised that there is after all a difference between l and r.h.d., in that the ball is offset backwards from center. According to the parts books the pitman arms are different for all left and r.h.d. cars between '30 and '54. before that they are interchangeable. If you were to fit a l.h.d. arm on a r.h.d. car the wheels would be not at the straight ahead position at the mid point of the steering box.0
Phil I thought I was going to have to make a drop arm and then I found a usable one.My thoughts about making one were to cut and shape a reasonable facsimile of the arm from 1" flat.For the ball I was going to put a tapered hole in the the bottom of the drop arm and bolt in a suitable size ball from a tie rod end.At the top I was going to get someone with an EDM to cut the tapered splines.bobwarddotlaidleyatgmaildotcom0
A person with a 1938T here in Adelaide South Australia had the ball welded and then remachined by a local business.0
Concerning welding Pitman Arms; Racers have cut & lengthened Pitmam (and Steering Arms) by re-welding them for Yrs to quicken the Car's steering ratio in the days before Quick Steering Gears..They would add a plate as reinforcement and.I never seen one break even though were Stick welded. The most important thing was to let it slowly cool . (I may still have a '37 Ball that I cut off if needed)...
Thanks All
We are having a new ball with stud made and then "properly" welded on with appropriate heat treatment
Thanks again
Phil
- 103 Hudson 1916 - 1929
- 28.5K HUDSON
- 172 The Flathead Forum
- 599 Vehicles
