52-53 rear axle bearing seals
Kerry, If you mean the OEM number of National 150066, Use CR 17310 NAPA 17310 or Victor 49218.0
Lance, I need both inner and outer axle seal numbers. Which one is that?
Thanks!0 -
Kerry, That one is for outer seals. I'll look for the inner one.0
Lance, I made a note on the first post.
Kerry, The one that I have for an OEM is : CR 15969-3. Currently interchanges with SKF 137100
