Wheel Cylinders
Are wheel cylinders interchangeable in all stepdowns? I have a '51 Hornet and wanted to know if it was compatible with the list of parts that "dougson" posted a few months ago for his '54. Front cylinders would be Bendix 33595 (left) 33596 (right) and 33600 (rear left) and 33601 (rear right)? Thanks again!
- Ray
Many Brands will Interchange with these Numbers from NAPA, Advance Auto, etc.
Bendix Wheel Cyls for rear are 15/16" either 33601 or 33600:::::Hornet Front Cyls are 1 1/8"Bendix 33220 and 332210 -
Stepdown brakes are much the same 48 to 54, only 3 types of wheel cylinder were used over those years.The rear wheel cylinders are the same over all years and models.The fronts came in 2 varieties, LWB all years and SWB 50 to 54.The 3 varieties all have the same bolt pattern so its possible to mix and match if you are careless.0
L.w.b. are 1-1/8, s.w.b. 1-1/16" on the front. All rears are 15/16"0
- 112 Hudson 1916 - 1929
