Moderators please address this
Why can't we cut and paste to this forum.
Several of us have asked and mentioned it in posts.
It's difficult to share when the links won't stick
Not sure I understand (that's not unusual, LOL!). I can copy and paste any posted sentences to (for example) an e-mail or an MS Word document. Are you saying that there should be a way to cut and paste an entire discussion by pushing a button or something?
Jon-I believe cut and past links, is his intention. I have trouble with that too from time to time and often takes 3 or 4 tries to get the link to "stick" to my post.0
http address links.
If I find something on a different forum and copy the address , then try to paste it here it won't
work.
This has been since the latest forum format started
Jon , I see you link the same things from AACA that I try.
Several others have mentioned that they can't show a link.
I'm guessing something blocking it?
I can put the same link on any other forum I go to.
SEEMS TO WORK JUST FINE....
HIGHLIGHT THE LINK THEN COPY VIA CTRL C
PASTE THE COPIED LINK TO YOUR POST VIA CTRL V
1 -
http://forums.aaca.org/f119/1952-hudson-owners-manual-380799.htmlhttp://forums.aaca.org/f119/1952-hudson-owners-manual-380799.html
OK , tried it. says web site can't be found when I click on it , if I click on second portion at htmlhttp it appears
** if you do not see 'paste' when you right-click in the text area (and I do not, at least not in Internet Explorer), just use the CTRL-V (Press CTRL and the 'V' key) to paste-in something that you have copied... **
'Key' sequences (vice the right-click & 'copy' & right-click & 'paste)':
- Highlight what you want to copy, and then press "CTRL" and "C";
- Put the cursor where you want the copied item to go, then press "CTRL" and "V";
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 554 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
