1951 hudson hornet
fatbelly15
i have a 1951 hudson hornet 4dr. step down long wheel base i orderd new door glass were can i find the window bottom metal run channels ? thanks
Contact Vic Zamora0
The door glass in a 1951 Hudson is mounted into metal frames. The metal frames are at the bottom side of the glass. These frames connect to the window closing and opening mechanism. Window glass is mounted into the metal frame with glass setting channels. These were rubber when manufactured. The rubber mounting channel is available from Wildrick Rubber Products in Shelbyville Indiana. If you are in need of the metal frames there are several people who frequent this Forum who sell used Hudson parts who can assist you with parts.0
ok thanks
- 115 Hudson 1916 - 1929
