1951 hudson hornet
Contact Vic Zamora0
The door glass in a 1951 Hudson is mounted into metal frames. The metal frames are at the bottom side of the glass. These frames connect to the window closing and opening mechanism. Window glass is mounted into the metal frame with glass setting channels. These were rubber when manufactured. The rubber mounting channel is available from Wildrick Rubber Products in Shelbyville Indiana. If you are in need of the metal frames there are several people who frequent this Forum who sell used Hudson parts who can assist you with parts.0
ok thanks
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
