Hudson Stepdown Frame
KTRON
edited January 2015 in HUDSON
Fellow Hudson enthusiasts,
Does anyone have good quality pictures of a Hudson stepdown either completely torn down, or just as a rolling chassis?
I am interested to see the overall structure of these cars. I take it the body panels can only be removed, and your left with a perimeter frame much like an airplane, unlike what might be found in your traditional "body on frame" vehicle.
Is the frame plate steel, tube steel, c-channel?
Galvanized? mild steel?
Thickness 3/16", 1/4" 3/8"?
Bolted, welder or riveted together?
Do they tend to rust from the inside out? Should any parts of the frame/crossmembers be reinforced if you plan on making it a daily driver?
At what point should a vehicle not be considered based on wheel well/frame rust?
Are there any other parts of the frame which commonly rust out?
I have only seen about a dozen Hudsons so far, and although some look really nice from afar, Ive seen some rusty wheel wells. How far is the frame behind them? Is the frame at all visible from underneath the vehicle? You cant exactly crawl underneath one of these, only lay on the floor and peek upwards?
Thanks,
Chris
