Oil filter canister
Were you looking to see how it's bolted on to the engine or how to run the oil lines? Regardless, I hope this helps.0
I was wanting to see how to run the oil lines. The problem I'm having with your picture is that when I click on it to blow it up, I can only see the front half of the engine from the oil filler pipe forward.0
Same here, I get that on many photos. Another aggravation we have to " Live with" with this new format ?
When I pass my mouse arrow over the picture, it becomes a small + in a circle. You place the plus over the area you weant to see blown up, and bingo, it enlarges that area.
I was able to scroll down and get to see the back half. That's the way I had installed it when I had it on the engine before. I will put it back on the same way when I get around to it.0
By the way, that is one nice looking engine Onerare39 and a neat engine mount, too.0
To view the entire photo try right clicking(PC) or control-click(Mac) and saving it to your computer and then opening the image off the forum using your computers photo viewer.Other option would be to change your monitor to a higher resolution -control panel(PC) or system prefs(Mac).This would put more pixels on your screen and allow you to see more of the photo.Sweet looking 308---power steering too!0
To see photos in full screen format , I right mouse click on the photo & choose "open link in new tab"
I use Windows 8 & FireFox.
Thanks Dave , that works. Most other forums it does it automatically. Still learning this new " improved" version.
- 96 Essex Super 6
