Stepdown Wiper Towers?
In attaching the cables from the wiper towers to the motor, I have come to find out that both wiper towers have the longer cables on them.  I need a tower with the shorter cables, or a known length and I can put new ends on them.  Would need na exact length for the latter option.
Anyone help?
  • Russel:
    Check Lance Walker
    J
  • Shorten the cables.  You can cut and join under the dash where it won't be seen.
  • RL:
    You can easily remove the two rivets on the tower, push out the pin and the pulley and wires can be switch out. I got plenty of shorter cable in excellent shape and can send you for free. 10 minute job
  • That's awesome, Russ, thanks.  Send them to me, please.
  • One additional bit of advice:  as you remove the post/pulley assembly be sure to take pics so you can recall how much cable to wrap around pulley prior to reinstall.  Can be a booger to figure out after the fact
  • Boogered if I care!
  • Got it Russ, thanks.  I'll install it this weekend.
  • Hi Ken
    Where did you get the cables?
    Lew
  • Yesterday while at local Home Depot found this cable available as by the foot bulk sale item.
