Hudson stepdown wiring size
Thought I'd post this as a new post so it doesn't get lost in the turn signal info.
The factory Hudson diagrams that I have seen, show the wiring routes, colors and sizes on the main diagrams but doesn't show the
wiring size on supplemental diagrams. Ken Cates looked this up and found an older post by Uncle Josh --
Hudson stepdown wiring size – not shown on original
diagrams.
I checked the source of
the diagrams and the original does not have wire gauge listing either.Some sleuthing of past
forum posts
Uncle Josh Senior
Contributor
October 2006 The stepdown
diagram has all the wire sizes. Generally
#1, Battery cables
#10, Starter sol to reg B term, CB and horn relay feed
#12, Ignition switch feed, gen to regulator A term,
horn and light sw feed, dimmer sw and headlamp feed
#14, ignition switch to coil, coil to dist., horn
button wire, tail, license feeds etc
#16, signal wires, quarter, courtesy lamps etc.
#18, indicator lamps
Thank you for the information.
Lee O'Dell0
- 112 Hudson 1916 - 1929
