Stepdown Wiper Towers?
RL Chilton
In attaching the cables from the wiper towers to the motor, I have come to find out that both wiper towers have the longer cables on them.  I need a tower with the shorter cables, or a known length and I can put new ends on them.  Would need na exact length for the latter option.
Anyone help?
  • Russel:
    Check Lance Walker
    J
  • Geoff
    Geoff Senior Contributor
    Shorten the cables.  You can cut and join under the dash where it won't be seen.
  • russmaas
    russmaas Senior Contributor
    RL:
    You can easily remove the two rivets on the tower, push out the pin and the pulley and wires can be switch out. I got plenty of shorter cable in excellent shape and can send you for free. 10 minute job
  • RL Chilton
    That's awesome, Russ, thanks.  Send them to me, please.
  • DavidC
    DavidC Senior Contributor
    One additional bit of advice:  as you remove the post/pulley assembly be sure to take pics so you can recall how much cable to wrap around pulley prior to reinstall.  Can be a booger to figure out after the fact
  • DavidC
  • Geoff
    Boogered if I care!
  • RL Chilton
    Got it Russ, thanks.  I'll install it this weekend.
  • EssexAdv
    EssexAdv Expert Adviser, Member
    Hi Ken
    Where did you get the cables?
    Lew
  • Glowplug
    Glowplug Expert Adviser
    Yesterday while at local Home Depot found this cable available as by the foot bulk sale item.
