wire supplier
J Lombard
I am re-wiring my '53 Hornet. I need the following colored wire, blk/red, blk/ylw & blk/grn. My local sources can't help. Does anyone have a possible source for this wire?
thanks
J
These folks have what you asked for http://www.magnetoparts.com/wire.htm0
Thank you one and all. Further question on wiring. On the '53 Hornet with Hydra-matic there is a light in the shift indicator on the steering column. Where does the wire leading from the light bulb terminate?
again thanks
J Lombard
Go to
https://www.brillman.com/
you can view the paper catalog which is hundreds of pages. I have purchased wire from them and it is excellent original looking wire, but it is modern wire covered in cloth. they also sell terminals. You can purchase wire in different lengths instead of buying an entire harness
