1937 hudson terraplane 6
scottanderson
I have above and need help as to the generator charging system....from the research I've done it looks like some models had a 2 brush gen. and a single contact cut-out relay before going to the battery , while mothers had a 3 brush system with a voltage reg.....mine is the first as described and the armature lug on the gen. goes to the cut-out switch which in-turn goes to the battery.....the field terminal has a cap on it and is not hooked up to anything.....the car appears to be completely stock............is this correct????also, I have had the gen. to a reputable shop and they tell me it is charging fine, but when I put a voltmeter to the armature terminal and the other to the battery ground(+), I get no reading????what am I doing wrong???????
Welcome aboard Scott!
Good to have you. I'm sure that folks will chime in, to assist you with your questions very soon. I've moved your thread to the 'Hudson' area, where I think it will generate more views.
While you are at it, you may want to look at our group on Facebook (see link at my signature below).
Members come for the cars, and stick around because of the great folks there!
If the "Gen Not charging" light is going out the generator is working. You will have a three-brush generator. It can be converted to a two-brush with regulator. With the engine running at a reasonable speed you should have around 7.5 volts at the armature terminal.0
- 109 Hudson 1916 - 1929
- 176 The Flathead Forum
