dry air cleaner part number
I am looking for the part number for the twin h dry air cleaners. I know there was a post a while back but cannot seem to find it.  Thanks Ray
  • Sorry I need the dry air cleaner filter element part number.  Ray
  • Ray, try NAPA 2110, Fram CA1-1PL.
  • I use Wix 42110 @ Amazon: $11.09 each
  • Duncan
    I don't recall the number I got for my car but I typed "air cleaner" in Search and found previous posts with list of part numbers to choose from.
    Lee O'Dell
  • From the post that Lee mentions:
    Fram CA372  H=3.06"  ID=4.67"  OD=6.06"
    Fram CA101  H=3.02"  ID=5"      OD= 6.39" bottom 6.69" top
    Wix 42110     H=3"     ID=5"      OD=6.35"
    NAPA 2110   same as wix, made by wix, slightly cheaper, wix slightly finer filter
  • Thank you all for your help.  Hudsonly  Ray
  • Paul
    Thanks for posting this. The post I saw was quite awhile ago that included other names but not the measurements.
    I'm sure it was CA101 I bought. Fits OK. However, there is very little air gap between the shield and top gasket. I will reconsider choice come time to change filters. .
    Lee O'Dell
  • If you have the later twin H from AMC, the E2550 from K&N fits very well.  Cannot vouch for the fit on the earlier square-throat cleaner
