dry air cleaner part number
Sorry I need the dry air cleaner filter element part number. Ray0
Ray, try NAPA 2110, Fram CA1-1PL.0
I use Wix 42110 @ Amazon: $11.09 each
Duncan
I don't recall the number I got for my car but I typed "air cleaner" in Search and found previous posts with list of part numbers to choose from.
Lee O'Dell
From the post that Lee mentions:
Fram CA372 H=3.06" ID=4.67" OD=6.06"
Fram CA101 H=3.02" ID=5" OD= 6.39" bottom 6.69" top
Wix 42110 H=3" ID=5" OD=6.35"
NAPA 2110 same as wix, made by wix, slightly cheaper, wix slightly finer filter0 -
Thank you all for your help. Hudsonly Ray0
Paul
Thanks for posting this. The post I saw was quite awhile ago that included other names but not the measurements.
I'm sure it was CA101 I bought. Fits OK. However, there is very little air gap between the shield and top gasket. I will reconsider choice come time to change filters. .
Lee O'Dell
If you have the later twin H from AMC, the E2550 from K&N fits very well. Cannot vouch for the fit on the earlier square-throat cleaner0
- 112 Hudson 1916 - 1929
