Emergency Brake Spring?
I sized up my original broken spring at the auto parts store and got one that fit. Not original, but works OK.0
Thanks Dave Ill try that.0
Home Depot/Lowes also have some. If you can match up the length, diameter and wire size of the coils, don't worry about the length of the hooks. You can use piano wire to fill the gap between the hooks and the attachment points on the brake levers or undercarriage0
