Speedo Cable
That's great I'm going to need a longer one for the Pacemaker when I put the O/D transmission in. Wish I knew the length I will need and I would go ahead and order it.0
This one was a bit longer than stock. I believe it measured 82-83in. He has the length on the eBay site. Don't know if this works for OD application but if the ends are the same as for hydramatics you should be good. I had som aleck I left near the MC0
Sounds plenty long. Appreciate the info. Doug0
- 112 Hudson 1916 - 1929
