frt suspension
Trying to figure out what kind of frt suspension to put under my 41 Hudson 2dr sedan, mustang 2 and frt frame stub, or a volare. I know some of the advantages and disadvantages of each kind just trying to get someother perspectives, and if anybody has done either upgrade. If I go with the M2, I know that I will have to either manufacture frt frame rails to work, or buy a stub from Fatmans. I have not looked at the volare frt yet for fitment.
I would go with the one that the parts are east to get.M2 parts easy to get and cost wise ?Not a lot of Volares left i n salvage yards.Fat man makes a nice product but a little much cost wise also.Just my two cents worth0
You might want to think about using a chevy S-10 frame of a ford ranger frame if the body fits .You can sit it on the new frame and have P/S P/B all up dated system safer to drive.0
I do have a friend who has a volare frt clip that I can get if I want it as he sold one of his project cars that he was going to install it on. I am also planning on upgrading the rear end with one from a newer mustang, the local salvage yard has a few that I believe that I can make work as far as track width. they have disc brakes and a 5x4.5 bolt pattern. I have not yet considered swapping the whole frame but might have to take a look at it also. Thank you for the advice0
I have a 1976 Nova front clip on my 53 Hornet. I am in the process of rebuilding the entire front suspension.
JC
Nice work!
JC0 -
fliptop, what is your track width and frame width with the nova frt stub? I am measuring my track width as 56.5", from hub face to hub face.
The front track width is 59.8" and the frame measures 2.5" H and 3 1/4" W.
JC
69 Camaro front frame clip on craigslist. North Fla.
http://lakecity.craigslist.org/pts/4997018287.html0 -
I decided to cut off the frt suspension, and front of the frame back aways , and fabricated my own front frame rails, which I slid inside of the original frame. I then boxed the frt of the frame, and have installed a mustang 2 style frt end from full tilt street rods.
Sound good let's see some pictures....
John
I went with 03 Ford Ranger front clip. It comes with tubular upper a arms, sway bar, disc brakes, and rack and pinion. Would have been perfect width for my 39 Country Club using regular offset wheels. Later, decided to install a 07 Ford Explorer independent rear which is 2 in wider so I now have a 1 inch spacer in the front so that I can run the later model offset wheels on all four corners.0
Looking good...Nice Ride!
JC
- 102 Hudson 1916 - 1929
- 17 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 992 Street Rods
- 172 The Flathead Forum
- 76 Hudson 8
- 597 Vehicles
