Essex headlight parts needed
Karl_Hamson
Hi folks
I find that I need just about all the internal headlight parts for our 28 Essex coupe. I have reflectors (L270) lined up thanks to Geoff but have found that the reflectors are foreign and do not fit properly as well as not accepting then bulb holders. The rims have been soldered and then plated but the mounting clips are missing. The buckets themselves seem fine but I would appreciate any help with the rest of it. I have plenty of 29 Hudson lights to trade. While I am at it, does any one have the smaller 10" 28 Hudson headlights? Ours are in terrible shape with no lenses, dings, cracks etc.
Thanks
Karl
Thanks
Karl
Oops it is the lenses I have lined up reflectors are needed
Karl0 -
Have you tried Donald Axelrod, 35 Timson, Lynn, MA 01902, PH: 781-598-0523? He sells complete headlights for antique cars but might possibly have some parts.
Karl, I can find you the reflectors most likely. You have the correct bulb holders? Otherwise, you can use Bedford truck reflectors. They fit right in the bucket, and the lens clips into them fine. I have them on my Essex. Only difference is adjustment is inside, rather that the screw in the back of the bucket. And they actually have a better beam than the originals. I usually see these at most swap meets here.Geoff0
Hi Karl
If Geoff can't find reflectors for then I may be able to. For a Canadian source, check with Brian Manning
Dave Young (NZ)
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 551 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
