Rocker chrome triangles
Due to the longer wheel base of the Hornet, the lower moldings would be longer
Thanks have a chance to get some to day but it maybe a wasp . I'll see if the vins still there0
51-53 rocker stainless dimensions (nominal) : Commodore/Hornet/Super 90" top 88" bottom.. Wasps/Pacemakers 88" top 84" bottom.0
Thats right I got it off Not much of a problem, Rust out on the rocker Looks good. Is there clips out there to buy or will i fab.something up for it . Any help or Ideas will be welcome, This is a driver not a Queen Thanks John0
There are reproduction pieces out there. The two that I know of make a series of short pieces and they are made out of galvanized metal, which won't build up rust. You can also put a small stainless washer between the new molding clips and the rocker itself and it lets water pass through and then little to no corrosion. The two suppliers I know of are Dellis Hudson (think I got that right), who has advertised in the WTN for ages. Also Wildrick Rubber Products (WRP) carries them. Last I heard, Russ Mass from 21st Century Hudson also has some clips, not sure if he has the ones for the rockers, but know he has some for the molding directly above the rockers on the bottom of the fender, door and quarter. Lastly, Lance Walker (posted on this thread) probably has some originals, if that is important to you. By the way, all Hudsons are Queens!0
Your Right should have said TRAILER QUEENS John0
- 96 Essex Super 6
