Overdrive governor
The governor on your transmission is located on the right side of the transmission opposite of the overdrive solenoid. . It is secured into place by means of a threaded base. The main body also a gear attached to it that slips into the gear case before the governor screws into place.0
Note that you don't have to remove the governor. Just remove the outer plate and you'll see the contact points on the underside of the plate. Handle carefully.
You can test in advance whether the governor is the problem. Just ground the wire that attaches to the governor and take a test drive. When you push the cable in, the OD should engage when you release the accelerator, regardless of your speed.
If it still doesn't work, the problem might be in the reverse cutout switch. Just follow the governor wire over to the rear of the OD unit, near the speedometer connection. You'll see the two wires going into that switch. Connect those two wires together and take a ride. If the OD now works, you've likely got a bad switch or oil on the internal contacts.
Thanks guys! I will take a look tomorrow when I get home from work.0
My website has maintenance and theory of operation information for your O/D. Also information on how to utilize a relay and switch to replace troublesome and costly OEM parts.
http://hudsonrestoration1948-54.com/index.html
Http://hudsonrestoration1948-54.com/Transmission.htm0
