Hornet Head Gaskets
I need to order a gasket set for our Hornet but the popular vendor has three choices regarding the head gasket: NORS (McChord, Fitzgerald, Victor or whatever), FelPro or something called "Pro-Torque High Bond". I'll bet there some opinions as to what is the best of those choices. Prices are virtually identical, but aren't a consideration anyway......I just want the best quality available. Any suggestions?
Frank
  • onerare39
    edited June 2015
    Frank,
    Not that you would really care but I have used the Best Gasket from Dale Cooper.
    There will also be some opinions regarding using Copper Coat, silver boiler paint, or nothing on the gasket.  I can't remember but I think I used Copper Coat.
    John Forkner
  • FYI
    Years ago, I used all the Brands with no problem, but today the Best Perm Bond is a far superior gasket..Randy Maas, 21st Century Hudson also sells the BEST 'Perm Bond' Head Gasket. They can be installed 'As Is', but I spray with K-W Copper Coat.  If spray the Gasket, hang and let get 'Tacky before installing.
    The Perm Bond doesnt come in the Gasket Set. You need order it seperately.
  • FWIT...I will use Best brand gaskets and nothing else
  • So......I see a mis-match in terms her,e but may I assume that Dale is selling the Best Perm-Bond and calling it Pro-Torque High Bond?
    I looked at the Maas list as well as Dale's. Olson's is right up the road from me and they are a Best dealer as well. I've done a bit of biz with them in the past so I may give 'em a shot, too.
    Thanks for the input.
    ps Doc, yes, it's going into the Coupe. For some reason it's got a leaky intake valve on #6 and I can't head out to Colorado without correcting that little issue......it won't heal. I'm doing a long list of maintenance/mods/repairs that have been waiting for me for some time, like timing components, PCV, exhaust manifold repair/mod, wiring, paint, trans/rear end seals, etc. The local tavern called Patty and asked if I had died.  Sorry......no such luck.
