Wanted Piston Ring set
Will post here because someone else might want to know about this company that MAKES piston rings. I had a set made for a 1931 Franklin and they were reasonable and excellent. They make rings from sizes 5/8" to 86" diameter. AMAZING~~~ located in Maryland. The air cooled Franklin had shallow rings and they are almost impossible to find.
So. if you don't find a set sitting around, talk to these folks: http://www.ringspacers.com/
Thanks for the tips Richard0
Check with Dale Cooper0
Thanks Larry!0
