Wanted Piston Ring set
Glowplug
edited August 2015 in HUDSON
Wanted: 262 engine, 0.040 over size rings for Hudson 4 ring 0.40 oversize piston set of 6. PM or email through forum.
  • Will post here because someone else might want to know about this company that MAKES  piston rings. I had a set made for a 1931 Franklin and they were reasonable and excellent. They make rings from sizes 5/8" to 86" diameter. AMAZING~~~ located in Maryland. The air cooled Franklin had shallow rings and they are almost impossible to find.
    So. if you don't find a set sitting around, talk to these folks:  http://www.ringspacers.com/
  • Thanks for the tips Richard
  • Check with Dale Cooper
  • Thanks Larry!
