Intake manifold plug
While trying to get my '49 262 super six running, I found this plug in the manifold that appears to be bent and needing to be replaced because of the gap it has.
What is this for and would it be a cause of the engine not running and sounding weak when it runs for a short while at best?
Thanks
  • That appears to be where the vacuum line for the wipers starts from. Normally there is a brass fitting and a steel line running over to the top input side of a double action fuel pump. If it's loose it well may be the cause of a vacuum leak causing engine problems.
  • Further investigation has found a crack in the exhaust manifold.
    Now I need one of them, anyone?
  • I'll check my pile of "stuff'.
  • Terrific Dave, I'll work with my fingers crossed until then.
  • That is an expansion plug,, which is used to  fill the hole left by the casting process.
    So I can just high heat epoxy it?
  • If it helps anyone, the casting number on my broken manifold appears to be: 112648
    Thanks everyone!
  • You should be able to get a new plug to fit the hole.
  • The plug has now become secondary to replacing/repairing cracked exhaust manifold.
  • I don't have a non-cracked exhaust manifold..Sorry
  • Thanks Dave
  • Is there an epoxy strong enough to use on this plug?
    And while I'm at it, where is the best lace to get new gaskets for this whole intake/exhaust area?
    Thanks for all your help!
  • Surprisingly had no trouble getting the plug, ordered the gaskets from R Maas
    Sent you a pm
    Thanks
