Hydramatic question
needed ? Or could there be an internal problem?
Thanks,
John
I wouldnt think sny internal problem if just replaced the rear seal. Ensure the transmission is really warmed up before adding more fluid. (Sometimes its difficult to see the actual fluid mark on the stick)..
Was the Torus full before the leak repair? I am guessing the fluid is being pumped into th torus to correct low level?.?0
PLEASE jack up the rear wheels or apply e brake very hard when putting in tranny fluid. Our car took off forward and bent in a little bit of rad support .Lucky I was not standing in front.Hudsonly Ray0
John-Ironically, it holds 11 qts., which was a surprise to me. Of course, that doesn't help you, if you don't know how much is in it to begin with. This is of course, in a copletely drained tranny. So, yes . . . it holds a lot! Keep going until you can see it on the dipstick while car is running.0
And block the wheels.Hudsonly Ray
And someone inside car with foot pushing on brake pedal.
Lee O'Dell0 -
Thanks for the insight. I will add more fluid until I get a good reading. T hanks for the safety tips.
John0 -
I inadvertently discovered another idiosyncrasy (wow, two twenty-five centers in one sentence!) if the fluid level is run too low. On the trip to Colorado, I had to back up for a distance so, of course, was in reverse.....also the lever position for "Park" when the engine isn't running (no hydraulic pressure). When the engine is running, the front pump supplies pressure to the system, thus applying pressure to the mechanism that locks-out the park pawl so you can go backward. If the oil level is too low and the oil is being aerated as a result, the parking pawl will engage while you are going backward! I'm very lucky I didn't break an axle or tear the parking pawl mechanism apart. Quite a shock. There may be other aggravating factors, such as excessive oil clearance somewhere causing a low pressure, but it's something to be aware of.
Frank
KenU exactly what happened to me.What a feeling trying to pull on the car that I have owned for 15 years going ahead and no time to react on how to stop it. Hudsonly Ray0
