gauges- 51Pacemaker
MissScarlett
The sending units for fuel and temp are functioning but the gauges don't provide accurate readings. What are appropriate next steps. My tech/electronics skills are limited.
The 51 Pacemaker had a windup clock or an electric clock depending on what the customer wanted. Don't know if yours is either--no indication from you.The speedo had a setup for several rear end ratios to work in accordance with the odometer and speedo head. Is your the origional ? Also, If gauge is no working :is it connected?, is the speedo cable membrane broken?, If you are not getting any lighting on the gauges, then I would check the wiring, or bulbs .0
Fuel and temp gauges are connected, reading are not accurate, light bulbs working0
Has any work been done on the car before the problem started0
