gauges- 51Pacemaker
MissScarlett
edited November 2015 in HUDSON
The sending units for fuel and temp are functioning but the gauges don't provide accurate readings. What are appropriate next steps. My tech/electronics skills are limited.
  • The 51 Pacemaker had a windup clock  or an electric clock depending on what the customer wanted. Don't know if yours is either--no indication from you.The speedo had a setup for several rear end ratios to work in accordance with the odometer and speedo head. Is your the origional ?  Also, If gauge is no working :is it connected?, is the speedo cable membrane broken?,    If you are not getting any lighting on the gauges, then I would check the wiring, or bulbs .
  • Fuel and temp gauges are connected, reading are not accurate, light bulbs working
  • Has any work been done on the car before the problem started
