Need a 6 volt Unity spotlight bulb- GE A 535
Hi,
I have dual Unity 6 volt spotlights on my Commodore. The passenger side one doesn't work. I'm assuming it is the bulb. Bulb is a GE A 535. I think the modern replacement reference # for this is GE 4535. It is a 30 watt, 6-8 Volt bulb. Where is a good place to find a replacement bulb for these? Thank you in advance, Niels
NAPA should be able to get you one, if not, Kanter0
Nielsnhp1127 wrote:Hi,
Before you change out the bulb check the light by putting 6 volts directly on the light. If it is wired to a switch remove the wire going to the light and run a hot wire from your battery to the light to check the lamp. Also check to make sure the light is getting good connection inside the housing. Better to run this test first... easier.. Remove the ring and pull the bulb... should have solid contact with one wire to the frame of the lamp and the other coming in as a hot wire from the switch. Both must be secure and making good contact.
BTW... spot light bulbs are sold on eBay all the time.
Good Luck0
