Rear axle inner seal.
Geoff, the old sealco number is not sure which is inner or which one is outer,but,the numbers were 1188 and 1302. I use a PBR seal number TC 12062. size 1.375x 2.750x 0.375. These are neoprene and should be available from your local bearing shop.Last one I bought was about $10. 00 .0
Thanks Les. As always you are a great help.0
Geoff, If you get stuck in that hole your digging, I have several in stock, but, you should not have any drama getting them from any bearing shop.0
- 112 Hudson 1916 - 1929
