Fuel pump Question 53 Hornet
AutoUpholstery1984
I need some info on what I can use that would match the original fuel pump. It does have the vacuum for the wipers? Can you steer my in the right direction? Thank so much!
These come up regularly on ebay, but you have to be careful buying an old stock item as the diaphragm could be a little perished. I believe Dave Kostansek still sells these, and you could check Dale Cooper at www.hudsonmotorcarco.com He has them listed as newly remanufactured.0
Do you want one rebuilt or do you want a kit? Also, what model of double action AC fuel pump do you have ?.Hudson used at least 3 different double action pumps on stepdowns. Lastly what year and model do you have?0
Thanks guys!0
Thanks for your help. Got it handled0
I've got 10 of them in the barn. Which one do you want. If they snort, they will get you home but all will need modern diaphragm for alky fuel, but they are no big deal to re-build.0
- 96 Essex Super 6
