Dual Action Fuel Pump
The dual action AC pumps for stepdown Hudsons will all interchange but different models were used for different years. The single action AC pumps will also interchange with the single action Carter pumps in their entirety. Just as a side note John, if you are to take your pump off for any reason BE SURE to keep the thick block to pump spacer washer. This provides the correct spacing for the actuating arm on the pump to the cam lobe .0
Does anyone sell the correct spacer washer for the dual action pump? Lance??regardsJ0
I have some extra dual pumps if you need 'em.. Should have new diaphragms. HETcramerlp@roadrunner.com0
J, Ken's right . Mine are pretty scummy.LOL0
- 96 Essex Super 6
