1954 hudson jetliner
i took my jetliner apart 10 years ago, now i have 5 steel blocks left over they are about 1 1/4 thick and 2"long with a 1/2 hole in the middle  does anybody know were the go?
  • What's the third dimension?  Or did you mean they're 1-1/2 x 1-1/2 x 2?
  • 2 1/4 long x1"thick x1 3/4 wide  1/2" hole in the middle   part# w3664a
  • I really have no idea where these parts would go.   The part number means nothing.   As it is unibody, there are no spacers between body and subframe. What bout something to do with Continental spare?
  • as i remember they went under the car somewhere  thanks anyway.
  • Red, have you considered asking a Jet "expert"?  Possibly Sarah Young could help you.  You may be acquainted with her "Jet" website: http://hudsonjet.net/
  • Did it have a trailer hitch ? The one I took off of my 49 Commodore had blocks about that size between the hitch and the frame.
    Geoff is a Jet expert. If he doesn't know, no one else would.
  • Well, I never thought of him!  ("Geoff" and "1928 Essex" are synonymous in my mind!).
  • Sounds like about the right size to go between the rear springs and the axle
  • lost mind you may be right,it did have a trailer hitch i will check there,thanks.
  • Only thing between the rear springs and the axle is a rubber pad.
  • thats it guys and gals  it was for my trailer hitch thanks everyone for the help.
  • looking for pin & bushing both sides [king-pins] for my 1954 jetliner  can anybody help?thanks.
  • Try Lester Harris @ 775-267-2559
  • is Lester Harris still in business he does not return my calls?
  • Just saw Lester the other day. Keep bugging him, as he is 84 years old and forgets sometimes.
  • Are you putting a trailer hitch back on your Jet?
  • yes i did Sarah thank you Claude [red rider]
