Borg Warner 3 speed manual with overdrive
? There are other suspects in that neighbor hood who should be investigated if not already done. Driveshaft universals, Transmission mount and the bolts, Center bearing mount cushions, Center bearing, Of course the rear transmission bearing etc. Hope it's not transmission! Call on Al Saffrahn in Maricopa AZ , he is the Trans/OD rebuilder0
Take a look at the front u-joint. If one of the cups has lost some of its wheel bearings, this can cause a lot of shaking.Per0
- 112 Hudson 1916 - 1929
