Clutch Alignment Tool
Where can I find a clutch alignment tool that fits a Hudson transmission? Also, is there another way, other than the fixture shown in the repair manual, to compress the engaging springs (CLUTCH Section 7-5 Figure 7, 1951 edition)?
I have made a clutch compression and dismantling tool out of angle steel and a long threaded shaft. The angle steel welded in a cross, fits over the pressure plate, and the shaft goes through the flywheel, with another peice of angle across the opening. Just wind the nuts on the threaded shaft down to take the pressure, undo the finger nuts and unwind the shaft nuts until decompressed.Geoff0
Easier yet, use the dowel and put a bolt in the end with the correct size head to fit the bearing.0
I just use an old input shaft. It has the common twist damage, but at a point beyond where it matters.
F
I bought mine from Russ/Randy Mass works very well with my 390
Back in 1981 I replaced the clutch, throwout bearing and pressure plate on my 1953 Wasp sedan. Used a universal clutch alignment tool, which I still have, that had various fittings to accommodate different sizes.0
My goodness, you can eyeball the clutch center within a few thousandths of an inch. The spline is easy to engage, and it's close enough for the radius on the end of the shaft to pick up the bearing when you're in there and release the clutch. I never use an alignment tool.0
High on my list of "least favorite sayings/phrases" is ......."Just pull it up with the bolts".
F
- 112 Hudson 1916 - 1929
