Wanted: Water outlet for Hudson 202
dbarrett
I'm looking for a good water outlet(thermostat housing) for my 1953 Super Jet with a 202. Thanks, David
David. I think they are the same as the stepdown. Try Lance. LHud0
i dug around and found one in my parts stash, but it is in pretty bad shape on the gasket side. I will check and see if Lance has one. Thanks, David
They aren't the same as the "Big" Hudson sixes. Somewhat shorter and used a different T-stat, which BTW, is a NAPA THM 55.
F
Oops! Correction: I meant to say, "NAPA # THM 155".0
I have several NOS Thermostat housings for the 202 Jet/Wasp. If interested, call me @ 616-six -seven-seven37-twenty.Casting # is 308019."Ric"0
Thanks for the help, I now have a new water outlet and a spare. Thanks again, David
- 115 Hudson 1916 - 1929
