Wanted: Passenger door window glass - 1950 Club Coupe
50ClubCoupe
Looking for door glass.
Thanks in advance,
Scott
Your Local Glass Shop should be able to cut you one for 25 - $30..Maybe a little more if need cut to pattern... For Channel and other Hudson specific window needs though contact Hudson Club Member Vic Zamora Glass Shop in Ca 562 947 5864
There are on-line glass sellers if your local glass guy can't do it...but I'm guessing it would be a lot cheaper to deal locally. Especially considering the added shipping costs.
Scott do you have a damaged example in your car? If so it can be used as s pattern. Most automotive glass suppliers have glass templates. Some have access to on line patterns. All the 48-54 coupe side glass us the same shape.0
I do have the damaged glass still in the car but I'm not sure if it will come out in one piece. I've seen the online sellers asking $115 for the one piece or $380 for the complete flat glass set. I'd rather spend the money on some other items before replacing the whole set so I was just curious to see if anyone had a spare window sitting on the shelf somewhere to get me through in the meantime….less hassle. If not I can try and remove it and have a pattern made. Are the driver and passenger windows the same? If so, I might just pull the driver window for a pattern.Thanks for the referral for Vic, I'll connect with him once I can procure a window.0
I just had a stepdown clear side window cut from an old cracked glass pattern for $25 +Tax and pick it up tomorrow....
