Flywheel Ring Gears
Frankvintagefullflowcom
Flywheel ring gear for all '40 (2nd type) to '54 Hudson (exc. Jet). Replacement for all manual transmission cars and trucks regardless of engine, clutch size or transmission.
Replacement for HMC p/n 160229/166277 gears. $110 ea. +shipping.
Frank Hughes, Hughes Machine HETFrank@vintagefullflow.com You know the drill......drop the HET
I'm adding a couple of photos in case there's any question about what this is.
...746) New Ring Gear, front (toward engine) w/seating chamfer.
...745) A closer look at that chamfer.
...744) Rear (engagement) side w/engagement chamfer for starter pinion.
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
