1947 pickup wiring diagram
I need a wiring diagram for my pickup. I cannot find it anywhere on line. How can I find one?
  • The 1947 Owner Manual has a very nice copy  included.  This can be enlarged for easier viewing/use.
    I took mine to Office Max , had them enlarge it and laminate in heavy plastic.  Very easy to use.
    If you don' have one, they appear quite often  for sale on e-bay.
    Good Luck,
    "Ric"
  • You've tried the H-E-T website, under "Library"?  I'd guess it's in the '46-7 shop manual, though I haven't checked.  Of course you would have to be registered to use the library, but if you're an H-E-T Club member you can do so and get full privileges.  If not, you can still register as a limited registration but I'm not sure if use of the on line library is included.
  • There is a very legible diagram on Pg 114-115 of the 1942-1947 Mechanical Procedure Manual.  Truck diagram is the same as the car.
  • Thanks I never saw it on the back off the fold out on the cover.
