Replacing the motor mounts on a 51Hornet -> Hydramatic
EngineerLecompte
I have every reason to believe that pretty much every rubber bit in the drive train is loose. I aim to replace the front and rear motor mounts and then move on to the driveline carrier if warranted. Is there anything I should know going into this? The front mounts seem easy enough, my lift is not set up yet to handle the....girth....of a stepdown so I can't quite see whats going on the transmission or carrier. Judging by the 65 years of benevolent neglect the car has had, and the clunking sounds under acceleration, I imagine dead mounts are not out of the question.
Thoughts?
R
Fronts are a walk in the park. Transmission mounts you will want your lift working and due to grease, oil and age and drivetrain weight you can bet they are bad. Do not hesitate to replace the center driveshaft support bushings. They are under-engineered from new and cheap to purchase and can be replaced with the car up on jack stands very easily. Wildrick Rubber recommended.
21stcenturyhudson.net has mounts in stock.
Randy
1-309-267-6158
- 96 Essex Super 6
