Shift Linkage Parts needed
SuperDave
48-51.. I need the two rods. I have a new bell crank. used or N.O.S. will do.
Dave what is it you need?0
The car I am working on (49) had Drive master and it has been removed, The shift linkage is much more elaborate than is needed for the single rod system.. I want to get rid of the superfluous stuff and go back to the simple two rods with the bell crank in between. I have a new bellcrank and only need the two rods.0
Dave - my bell crank for my '50 non-OD is severely worn and I'm looking to repair/replace it. Did you find a source for a new bell crank or where you able to procure a NOS unit?Scott0
Wuz lucky to find a N.O.S, many years ago. Don't recall where.0
