Redone gauges near completion!
GrimGreaser
Have my tach/speedo and clock/fuel setup just about done. Center gauge will have volt/temp/oil. LED lighting.
nice work. Are the LEDs dimable?
WOW! That is impressive. Looking forward to seeing finished gages.0
The LEDs can be dimmed. A potentiometer will dim them until they turn off because the voltage drops too low, or a PWM dimmer can be used to get better output. I hardly ever touch my dash dimmer, though.0
Thanks, Did my IH scout about 10yrs ago and they wouldn't dim so it got pretty bright at night.0
Grim,
Looking Good! Glad to see you making progress on your gauges.
Larry
