Wanted: Hudson Jet front suspension parts
dbarrett
Looking for the following Jet front suspension parts:
159739 - Bushing, lower arm pivot - need 4
308190 - Seal, pivot pin lower - need 2
308191 - Bearing, pivot pin lower trunnion - need 2
308192 - Cover, pivot pin lower trunnion - need 2
308193 - Seal, pivot pin thrust bearing - need 2
308195 - Seal, pivot pin upper- need 2
308210 - Seal, lower support arm trunnion bushing - need 4
308218 - Bushing, pivot to upper arm- need 4
Any help is greatly appreciated,. David
You want new ones or a Jet in a junkyard?0
Would like new parts if possible. Thanks, David
David give me a call please...0
