Looking for clips & light bulb housing
Hi everyone. I'm looking for some small parts for our '54 Hornet. The back-up light bulb housings/sockets are in sad shape. I might be able to clean them up but if there is a source for them, I'd prefer to go that route. Also, I'm looking for the metal clips that hold the door panels to the door. Any leads would be appreciated, thanks.
Tim in WI.
Pretty sure I have what you're looking for Tim. Call me at 704 seven nine two 9110.0
Try NAPA for Chrysler panel clips or
Restoration Specialties & Supply, Inc.
www.restorationspecialties.com/0 -
Hi Dave, thanks for the lead. I'll check them out.Hey Lance, when would it be a good time to call you tomorrow, (Friday the 24th)?Thanks guys.Tim0
Tim, Sorry for not getting back earlier. Tuesday night would be great.0
Something to think about. Many of us have gone to the dual filament sockets for the back-up lamps. They too can be found in the clip type very easy at NAPA. (they are the same ones you use in the front and turn signal lamps.) Wire both the filament wires together and get far better light then a single filament without having to resort to obsolete or difficult to source high wattage bulbs.Just putting another idea out there for your consideration. If you are a purest you won't do this. but it is an idea.0
- 112 Hudson 1916 - 1929
