Spark Plug Wires
I aim to replace the leads on my Hornet. How do you run the wires through the gadget on top of the block? The gadget seems to be solid, and does not lend itself to being taken off the block easily. The set I bought from NAPA do not lend themselves to being taken apart, so I am wondering if there is a preferred part number that will fit? Is there some kind of trick to it?
R
No trick, the easiest way is to get the kit that you put your own ends on. You fish then through and then put the ends on once you cut the leads to0
- 112 Hudson 1916 - 1929
