Dale Cooper has the new sway bars in stock.
Mine is currently in transit. Will post findings when it's installed.0
WOW, excited for you guys; been driving with mine for about 8 months now. AWESOME !!!
Can theses sway bars be fitted to a 1940?
The HD bars are basically the same as stock stepdown except diameter; they had a stock bar when made and were patterned after that stock bar. SO, borrow a stock bar and check.0
I thought the 40's were narrower than the later Step Downs.0
I put an order in about two weeks ago. They're out of stock again, but more are coming. If you're thinking about it, probably want to call and get on the list for the next wave. Not sure how many he has coming, but he is expecting them to come a lot quicker than the first batch he had ordered.0
Sorry for the delay Kerry, bars are going into production tomorrow.
From ADDCO
Thank you,
To 'whet your appetite': HD bar vs orig anti-swaybar
1st is HD bar
2nd is stock bar but with new links and poly bushings {if you don't get an HD bar, for goodness get aftermarket links and poly bushings; but get links that will make the bar arms level with road; my aftermarket ones shown with orig. bar are too long~~}
Thanks for posting the comparison photos.0
Another showing difference. The cross section area of the HD bar is 2.3 times the area of the stock Hudson bar.
PIE are square !!!
top & bottom are HD
middle is OEM
For us non-matheticians,
What was the OD of the original anti-sway bar?
And what is the OD of the new HI anti-sway bar?
Did Hudson offer a Severe Usage sway bar and if so, was it the same ID as this new bar?
orig: 3/4"
HD: 1-1/8"
no info0 -
Talking to Dale Cooper the other day, and he said that it was odd that Hudson offered a Severe Usage bar for the Jet, but never did offer one for the Stepdowns.0
Well, for sure the Jet could put a heavier bar to good use ! It's rather clunky to go into a tight turn with the standard sway bar. But then, I guess that most people that bought economy cars up to that time were not in a habit of forcing the car thru a tight corner at speed !
How do those these new bars perform? Is body roll significantly reduced? Does it compromise the ride quality? What is the cost for something like this? Would I need any special tools to install?0
This is what I posted on the other forum:Just got back inside from road-testing with the new sway bar. All I can say is, "WOW!". Virtually no body roll even hard into turns. Car floats through flat, true, tracks like a dream. I'm very pleased with the results. If this car had radials, it would be quite a ride. I've got to get another bar for the sedan now.
Really, if you think about it, along with metal fatigue, I'm sure the stock sway bars get sloppy over time and it's inner tensile strength is (most likely) not what with which they started out life. That would allow considerable more flex, translating to more body roll. Money well spent.No special tools needed. If I remember right, they cost around $2500 -
Is this something that can be installed using a floor jack?RichardD, where did you get those links and bushings? Do they simply bolt right into the existing holes?This is tempting, because my '54 has crazy body roll...0
You get the complete set, Powder coated bar, links, poly link and frame bushings, and brackets. Think I had to file some on the bracket holes but not much. At least that is the way mine came.
You will NOT have body roll with this item---at least I don't: "ANY"{no 90 degree curves at 100 tho lol}.
Floor jack will work but you shouldn't have one side higher than the other.Believe you can do this by laying on the floor without raising the car.
Yes, on use existing holes. I did buy new grade 8 bolts for the frame brackets,and chased the threads, & double nutted the links.Every stepdown should have this item; perhaps except trailer queens.
You agree, Russ?
I'm on the next order for the Hornet project. Will eventually get one for the Pacemonster, lol.0
How does the heavier sway bar affect the ride quality?0
to me the car just feels better more firm, but the real prof is in the corning
dan
I think I'm sold... How do I order?0
http://www.hudsonmotorcarco.com/
Give Dale a call ----- He carries a full line of Hudson mechanical parts as well.
Agreed, Richard. Better ride, better handling. Win-win situation. I love mine. I want to get another one for my sedan.0 -
Are these bars the same quality steel as a stock bar would be? Just concerned about safety. Thanks0
Company has been making anti-sway bars for 52 years without a problem. Probably would depend on how fast you drive ??
Airbrushguy, I can't give you any specifics on the metallurgy, but I can tell you that I'm VERY happy with the bar I purchased.Some notes:-The bar is MUCH thicker and heavier than the stock bar. It's not even close. It's powder-coated and seems super-heavy-duty.-The supplied bushing brackets and washers didn't quite fit my 1954 Hornet - they were too small. Simple enough fix, I just had to file out the bolt slots in the brackets, and use different washers.-The bar is so thick that it was not going to clear the metal "tray" under the radiator (sorry, I don't know the proper name for this piece). Again, it's a simple enough fix, as I plan to simply trim the piece a bit.With all that being said, I am very glad I got it, as I no longer feel like I'm turning a WWI-era biplane... :-)0
photo of stock and HD bars {0.75" vs 1.125"}; stock bar in center; HD bars top and bottom.
click on photo>>
Does he have them in stock? I sent him email but he didn't reply.0
call phone number !!!0
- 102 Hudson 1916 - 1929
- 16 Upcoming Events
- 90 Essex Super 6
- 28.5K HUDSON
- 552 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 73 Hudson 8
- 597 Vehicles
