28 Right Hand Drive Essex Dash Switches
Hi All,
Could someone kindly post or send me a photo of an original 28 right hand drive Essex dashboard showing the correct location of the light switch or switches.
Can someone also recommend a supplier for and make/type of switch to suit headlight and cowl lights etc of the correct type, I assume the switch would be suitable for the levers as attached photo reproduced by Vintage and Classic Reproductions?
Many thanks,
Ensignman
Many thanks,
Ensignman
The switch is located at the extreme right hand side of the dash. The original handles were pot metal and swell up in the hub, which makes them eventually seize and break off.0
Thanks again Geoff,
I assume then that the switch should work the sidelights, main beam and dip.
Anyone know a type/supplier of switch to suit those handles?
Ensignman
Yes, it is a three-position switch, - side, high, and low beam.0
- 174 The Flathead Forum
- 601 Vehicles
